" IMPORTANT SAITO ENGINE TECH NOTE!!! The crankcase vent must be kept open to the atmosphere. This is NOT a pressure tap. It should not be connected to the fuel tank. It's purpose is to allow excess crankcase oil to drip out and it must never be sealed. It is convenient to connect about 4 inches of fuel tubing to this vent so that excess oil drips can exit outside the model; the fuel tubing is also useful because it is easy to squirt after-run oil into the crank-case through this tube."
From Saito site (clik)
I found that JUST in time!
"USING A SPINNER: Plastic spinners are unsuitable for engines like the Saito-91 and larger."
Huh???
"Overall, getting a spinner to fit with the right adapter and right length bolt can be a real pain. Chances are that the TT-0823-A adapter will work for you; if you have a very thick prop you may have to try the TT-0822-A version. The adapter TT-0825A will also work but does not have a jam nut.
The bolt (5mm thread) that comes with Tru-Turn spinners maybe the wrong length for your particular setup and getting a suitable size replacement can be a challenge."
Oh, GREAT!!!
Prop, spinner & nut info
Ooohhhh...be SURE to see the Saito fuel system page!!
Might want to use 1/8" fuel line, Perry VP-20 pump, Cline regulator.
Saito quote: "Many people report greatly improved performance after switching from the Saito plug to the OS F-type plug"
Tons of good info at this site!............Dave
