RCU Forums - View Single Post - bvm smoothstop problem
Old 10-26-2007 | 08:05 AM
Jetkopter
Default RE: bvm smoothstop problem
ORIGINAL: Adil Nasim
ORIGINAL: Jetkopter
Adil, did you buy the real smooth stops or the Asian ones I have over a hundred flights on the Bobcat now and its never given me any problems nor have any of my other 5 smooth stops.
Don
Dude, I don't think you have TOTAL 100 flights on ALL your planes let alone the Bobcat. It may be a good product but requires TOO much maintenance for my liking. Now your situation is a little different - your planes get too much pampering but not enough usage...
Adil
Are you sure you want to do this, You forget all the flights you put on it when your Asian airplanes where broken and you already broke or destroyed any good made in the USA planes you may have owned. I understand your reasoning for flying what you fly, there cheaper by the dozen I need brakes that work on my planes. I understand you could care less about the smooth stop becuase from what I have seen your gear most of the time wont go up and if it does come down it always collapses and your plane is stopped even before you can reach for the brake switch.[X(] And whats with your Bandit , do you want me to give you some tubing so you can hook up that front gear. Im sure the instructions say to use air line and not just gravity to make it come down. And speaking of maintenence maybe if you did some your stuff would work. Thank god you just joined a club with a grass field.
