RCU Forums - View Single Post - cen funfactor 2-speed shift problem
Old 10-26-2007 | 03:29 PM
CEN Racing's Avatar
Default RE: cen funfactor 2-speed shift problem
cougar does the car seem to be getting to high speeds if so you need to tightne the shift point because it is shifting to soon. also when you replaced the motor did you replace your clutch or are you still running the same old clutch if so you might need to get new shoes they might be worn out and not grabbing
