What changes at the AMA are DESPERATELY needed?
This seems to be a common lament on the AMA Forum, here on R/CU. I would guess this question has been asked many times before; however, I don't recall seeing it. The election is going on, two of the presidential candidates are posting here as we speak. This is an opportunity to make your points known, so take the time to post what you'd DESPERATELY like to see changed!
I would suggest posting changes you'd like to see happen, which would be better for all the membership, as opposed to changes benefiting only your special interest group (SIG). This is only a recommendation to attempt to get you to think globally, as opposed to individually. Yes, SIGs have issues and if this is what you feel is needed, go for it; however, excuse me for not seeing your special needs as something the AMA needs to DESPERATELY change!
