RCU Forums - View Single Post - Sig King Kobra Build
Old 10-27-2007 | 09:55 PM
ExperimentalAviator's Avatar
ExperimentalAviator
My Feedback: (15)
Default RE: Sig King Kobra Build
Watch out for this potential building error!
The fuselage bulkheads are precut but the wing dowel holes are not drilled. You have to use the blueprints to layout the wing dowel locations on F2. In my application the dimensions on the blueprints did not work and the center of the holes did not line up with the centerline of the wing leading edge. The wing sits in the fuselage perfectly so I'm at a loss as to why I have to make a correction here.
Anyway, I will have to plug the holes in F2 and re-drill at the correct location.
Mike
ID:	791855   Click image for larger version
