sheeting turtle deck RV4
Use a mix of ammonia and water, the ammonia helps the water to soak in and expand the fibers. Don't worry about the wood glue, it will dry just fine. I use wood glue when I apply sheeting. Have plenty of pins on hand to pin down the sheeting. It also makes it easier to sheet if you wet the sheeting and wrap it around a pipe or can and hold it in place with rubber bands till its dry. The sheeting then will be prebent for you.
