RCU Forums - View Single Post - sheeting turtle deck RV4
Old 03-29-2003 | 05:58 AM
Devo
Default sheeting turtle deck RV4
You can wet the sheet, pin it or tape it in place and allow it to dry before glueing. After it dries it will almost conform to the shape you want by itself. You could also use thin CA while the sheet is wet. I use a 50/50 mix of rubbing alcohol and water.
