RCU Forums - View Single Post - Carb mounting blocks
Old 10-28-2007 | 03:13 AM
pe reivers
Default RE: Carb mounting blocks
ORIGINAL: andy86na
What is the material used to make the blocks? It feels like plastic. Where could I get it--as a 4X4 slab or something like that?
Thanks.
You can make your own using print board. Laminate pieces up to the required thickness using 24hr epoxy and moderate clamp pressure to drive out excess glue, but not starve the joints.
