RCU Forums - View Single Post - Carb mounting blocks
Old 10-28-2007 | 12:05 PM
mikenlapaz
Default RE: Carb mounting blocks
You can make your own using print board. Laminate pieces up to the required thickness using 24hr epoxy and moderate clamp pressure to drive out excess glue, but not starve the joints.
Excellent!!
I used some 1/8" plywood and West System to achieve my first homemade heat dam / insulator.
