RCU Forums - View Single Post - AirForce One Plane Kit
Thread
10-28-2007 | 12:10 PM
14
ARF Guy
Oct 2005
145
Prescott, AZ
RE: AirForce One Plane Kit
Got the AF-1 at Big 5 Sporting Goods a couple months ago for $56 on sale. I put a Futaba 2.4 receiver and a programmable 35 amp ESC in it to run the brushed motors with a 3 cell li-po. I made some landing gear and installed 4 cheapie mini-servos for ailerons (2), elevator (1) and steerable nose gear. I looked at a 3-view drawing for a guestimate on the main gear location and balanced it where it balanced stock with the battery pack. I had some issues with the negative incidence on the horizontal stab since it was meant to fly with just thrust but work around that rather than cut them off and re-align them. Full power for take-off uses about 300 ft of our dirt runway (I'm sure paved would be much less) and it rotates just like the real thing. I reduce power immediately to reduce its natural tendency to climb and the thing tools around at a very scale-looking speed. Stalls just mush straight ahead and even here at 5500' above sea level, it’s almost a powered glider. I use a 1450 MAH pack and it gives me plenty of flying time. It will also lift my 2200 MAH "Stryker" battery but the extra weight makes it fly a little faster.
Wind sucks! It will do a weird wallowing, especially when slowing to land but landings are a piece of cake! I carry a little throttle right to the ground and flair to a scale nose-high landing. So far this plane is the hit of our flying field and a hoot to fly.
ARF Guy
Reply
Like
ARF Guy
View Public Profile
Send a private message to ARF Guy
Find More Posts by ARF Guy
View iTrader Profile
