Some questions...
What type of aircraft is this going in? I've seen lots of very good setups, but some are better tailored to certain airframes. Will this plane have an internal, or external (on the bottom of plane) pipe tunnel? I have some links to pics of different setups also. On my particular plane, I had custom made aluminum mounts made. i used thin gauge SS to hold the pipes to the mounts and used AeroTrend blue silicone (large) for dampening. There are lots of ways to mount these things. Actually if I had a pic of your plane where the pipe would be going I could give you much better info. . I like to think I'm pretty good with these pipes. It's one of the things I have studied up on for awhile. I've always liked that pipe sound and have run them from when I first started in GS aerobatics seriously. Even before I got into GS aerobatics myself, I built a few 30%'s, and 35%'s with pipes in them some time ago. You'll find that there is alot more things available, and alot of good websites on this. If you can give me a little more info. I can give you a more detailed answer. If you would like, PM me, and I'll send my e-mail to you so we can exchange larger images and things if nedd be. :-)
