RE: Focus Sport 110 YS Powered
It was really windy today but I was able to get one flight in on my Focus Sport. The control throws per the manual were a little to much on the Ailerons and made it really touchy. The Rudder was to much as well and made ground handling a job to keep the plane straight down the runway. The Elevator seemed ok. The plane seemed to track very well inspite ot the gusty wind conditions. The Saito 125 looks like its going to be fine on the business end once I get it broke in and leaned out all the way. Today was a very rich run but it did very well. After I landed I noticed that three of the four 1/4" by 7/16" blocks that the cowl is secured to had come out of the firwall. Very little glue here and I guess I missed getting some epoxy in this area. I noticed three balsa sticks about 3" long with some foam on each side laying in the fuse that had come loose from the tail section inside the fuse. I'm not sure if this will be a problem or not but after only one flight the plane seems to be coming apart. It was so windy I'm not really sure how the plane performed but I did have to add a lot of up elevator to get it to fly level so maybe soom of the weight I added to get the CG spot on can slowly be removed.
