RE: Moki 1.8 conversion
IF you want to run gas, buy a gas engine.
If you must Ch has the parts to convert a Moki. Its simplest to run 10% oil mix.
To run needle bearings on a Moki is a major conversion. You can't sleve the crank pin, because its hollow and will be to thin after grinding. So you have to machine off the crank pin and then press in a hardend pin.
