RE: Skymaster F-4E phantom
HI Guys,
I am running into a glitch with radio setup wondering if someone may have an answer:
I have a JR PCM 10X with Spektrum Module AR9000 RX (9 chan only) so I decided to use AUX 2 for my flaps .. aux 2 into powerbox out to matchbox, out to 2 flaps. now the problem is when I mix in the Flap Switch into the Aux 2(flap) ch, I cannot get the servo travel, offset correctly and cant get it to do a 3 positions.
My main problem is that the manual for 10x doesnt explain how to setup flaps into an AUX ch stepwise.
My two specific problems are:
Offset only goes to -84 or 0 (niether are good zeros)
once u set an offset I still dont get 3 positions... without offset (0) will not get 3 positions either.
I can just Include AUX 2 switch. but that switch is middle and two extends...
If someone has a 10x setu similar to mine and can tell me step by step, will appreciate it very much.
Also, has somebody tried mixing a little flaperon with flaps on the F4 to see the outcome? Does it need it?
tx
jason
