RE: sv27 question
I use the 440/3 and am very happy with it. Others report good speed from CF48 props but this is an aggressive prop and may overload your ESC depending on what batts you use. The standard motor and ESC should get you to low 40's with a good prop and some good batts or lipos. Beyond that you'll need a motor and ESC upgrade.
