RCU Forums - View Single Post - Walkera Dragonfly #36
Old 10-29-2007 | 06:34 PM
  #9628
Rollin Thunder's Avatar
Rollin Thunder
Default RE: Walkera Dragonfly #36
Don't worry about the tail while the main blades are still out of track. Be sure the tail pulley isn't slipping. Use a drop of CA at it's base if it is. Also check that your belt isn't to tight. So get those blades tracked and good luck.
Ron
