RCU Forums - View Single Post - Edge 540 wants to torque roll really fast when you try to hover..??? PLEASE HELP!!
Old 10-29-2007 | 08:41 PM
highhorse's Avatar
highhorse
Default RE: Edge 540 wants to torque roll really fast when you try to hover..??? PLEASE HELP!!
I will leave the discussion with this thought
If it takes 10 lbs of thrust -to hold in stationary hover a 10 lb model -using a simple single propeller - - the prop will need a given amount of power (hp) to do that job . not more or less
the reaction of the applied power at the prop will be equal to the force turning it..
swapping props -as long as the setup will still just hover the model -- will result in same "torque rolling effect".
Oh-My-God...this is going to drive Dick and me nuts. Or at least me
I'm gonna try to make my point one-more-time. Then, hell or high water, I'm quitting. ( I know Dick's thinking "finally!!")
Please picture in your mind any two identical props on two identical planes of identical 10.00000000 lb weights. Two identical engines burning...you get the point.
Hover them at the same time. Same TQ roll tendencies, right? NOW THEN, glue POPCICLE STICKS to the blades on one model. Sideways. THAT model now has a very inefficient , goofy prop. THAT one will use a lot MORE power to make the same 10 lbs of thrust due to the very draggy and goofed up prop. The extra drag being overcome at a higher rpm to make the same 10 lbs of thrust will burn more calories or amps or watts or joules or frigging dilithium crystals for all I care.
But it will, it WILL, according to none other than Mr. Newton's 3rd law, have MORE TQ ROLL.
There, I'm done. Whew...feels good
POWERLINES, in redneck-speak (as per your request) SWAP PROPS. Experiment. Enjoy. Bet your buddies beers on the outcome.
It's all your's now Dick. I'm worn out.
Thanks for indulging me, Don.
