RE: WHAT HAPPENED???????????????
The only thing I can think of is you turned the plane around before you added the weight. That would make your right wing on the right and your left wing on your left but if the plane is facing toward you when you checked the balance then the right wing would be on your left. Does that make sense?!? [8D]
