RE: Problem with TT .46 pro
I agree...it might be inadequate air flow through the cowl? Have you tried flying it without the cowl?
Also, check all the screws...you might have an air leak at the backplate or a loose head? And make sure the carb is fully seated in the case and the O ring is still there and not damaged.
Also, I think maybe the 10X6 is a little small for that engine?
