Another gy401 setup question
Hey, got some questions about my gy401/9253/9CHP.
1. ~50% throw on the rudder gives me 100% throw on on the servo. My rudder ATVs are 100%. Neither adjusting this or the limit setting on the gyro seems to fix this. How do I get get full throw on the stick to equal full throw on the servo?
2. The instructions say that a a steady flashing light indicates ACVS mode. If I turn on the gyro while the radio is in ACVS mode, the light come on solid, no flashing (after the initial setup flashing). Otherwise it seems to work ok. Is this normal.
3. If I turn on the gyro while the radio is in normal mode, the light gives me a steady flash, and doesn't change when I switch to ACVS mode. I assume this has something to do the the gyro needing to be started in ACVS mode. So what do I do if I want to fly with the gyro in normal mode and have the radio in normal mode (no idle ups), becuase the 9CHP errors is I'm not is normal mode when it turns on?
Ryan
