I own and fly the following, MoJo, Primo both from Paul Swany plus Edge V3 and Fusion both from OMP. In order of preferance it goes Primo, MoJo, Fusion, Edge.
If you can fly all out 3D the Primo is the way to go, just learning go for the MoJo. Both offerings from OMP are great planes just not as nimble/stable. The Fusion is better @ standard aerobatics mine has a really hard time in high alpha flight.
Right now the MoJo is available as an ARF along with the Edge and Fusion, the Primo only as a kit.
If you build the MoJo can be ordered with a removable wing option in both 40 and 60 size. The Fusion and Edge ARF/kits come standard with removable wings.
http://www.swanyshouse.com/index.aspx
http://www.ohiomodelplanes.com/
See links and go tear it up!
Eric
