RCU Forums - View Single Post - warhead evo?
Thread: warhead evo?
Old 10-30-2007 | 03:38 PM
-EXTRA-'s Avatar
-EXTRA-
Default RE: warhead evo?
ORIGINAL: choops01
DO NOT BUY THIS TRUCK!!!!!!!!!!!!!
It is a maintenance nightmare.
ask anyone who has one how hard it is to remove the engine.
You need to disassemble the whole truck and since you stripped all the screws taking it apart you should replace them.
after they explain to you how to get the engine out ask them how to remove the transmision for maintenace or to replace the spur gear.
will not even get into the worn out drive pins or the cracking motor mount.
Former warhead owner.
Steve
Actually i just got done taking out the engine in my dad's warhead to put the Roto start on it and put it back in took me about 5 min. all you do is take the header off the back unscrew the primer tank and take the 4 bolts out and there it is simple,and to replace the spur gear unscrew the 1 screw on the carb take it out and the spur will slide right off.and stripping all the screw's?use the right size screwdriver and you wont have a problem.
