RCU Forums - View Single Post - Problem with nuts & prop
Old 03-29-2003 | 07:49 AM
Woodsy
Default Problem with nuts & prop
I asume that the nut is not bottoming on the thred? also does the prop drive plate have good grooves/hatches i it? to undo the nut like that the prop has to be moving, a backfire will not loosten the nut on its own, its using the inertia of the prop, try using a washer made from roughsand paper on either side of the prop.
