RE: Problem with TT .46 pro
Thanks guys for giving me so much to check. I checked the small flathead screw, and it was a bit loose. also, the backplate bolts were just snug, so I tightened them.
I also stripped my carb, and there was a little piece of goo in the needle valve area.
Checked my pressure fitting on the pipe, and it was ok
I am going to bring another muffler to try at the field if all that does not work!
Hopefully this stuff will work, I will know tomorrow!
871
