RCU Forums - View Single Post - Glue Question
Old 10-31-2007 | 08:37 AM
Panther F's Avatar
Panther F
Default RE: Glue Question
When I use resin or Plastruct and it's large pieces I'm putting together the CA works great if you tack it in certain spots giving it an anchor, then go back and use the welding type glues or even a fast setting epoxy for resin. Working that way you're not fighting the project and getting a perfect bond as well.
If it's just a small area, then the CA works best. As long as the area has some voids or gaps to fill, the drying time has been eliminated. Just make sure it is straight and it's where it needs to be before you shoot it with the kicker.
Jeff
