RCU Forums - View Single Post - Saito 180 starter?
Old 10-31-2007 | 01:03 PM
bruce88123
Default RE: Saito 180 starter?
ORIGINAL: foresterxt
ORIGINAL: snacker
ORIGINAL: agexpert
I have a cordless starter which will turn a DA 50 all day long.
It's called a Heli-Max. I don't know who makes it, but it cost me only $35 a year or so ago. it requires two 6-cell nicd packs @ 20$ a piece, but it's the best starter available.
Hope you can find it. If not, I will sell you mine with batts....I have moved to gas, permanently.
It's probably the Heli-Max MiniMax starter http://www3.towerhobbies.com/cgi-bin...?&I=LXLMT5&P=7
I just ordered one last week, should be here on Monday. It uses a gear reduction so it should have excellent torque. I burned up my direct drive tower starter trying to get my heli started. It's amazing how little torque some of the starters actually have. You can grab the cone by hand it keep it from turning with very little effort. The Heli-Max starter looks to be one of the best starters on the market for the price. I'm surprised there is so little information on it in the forums. I'll report back next week and let you know how it works.
Cheers,
Dave
Well, scratch the MiniMax. It's a cool little starter (about half the size of a normal starter), but it just have the twist. I couldn't even get my TT 1.20 started with it. I'm sure it's fine for most .91 and under motors or a 4-stroke with lower compression.
Maybe I'm going about it the wrong way. Since my hobbico starter will start the Saito 180 when hooked up to a car battery, is there a compact field box type battery that will put out the same type of power a car battery will for a shorter time. Maybe a lipo?
To bad about the MiniMax. Thanks for letting me know.
It's possible that you're field battery isn't up to par in which case you can just run down to just about any store and pick up a motorcycle battery. What you're really after here is voltage, not mAh capacity. I would (and am in the process of) putting two 8.4V RC Car packs together (16.8V) for an extra boost. Most starters can easily handle more than 12V. On a side note, I picked up a Sullivan Dynatron starter. It's a little more expensive, but it works really well on 12V. It's rated to run up to 24V so you should be able to turn over any engine out there with this starter on 24V.
On the contrary, it is all about the MaH. Why do you think they put high capacity batteries in cars that live in cold weather all the time? More cranking power. You CAN substitute more volts but will need some capacity to do the job. 12 volt motorcycle or lawn tractor battery is a good method.
