RE: SLOPE FREE SERVOS ?
... 100 flights is short ...
At the same time i should be careful to judge, i have just tested these 2 in a relatively short period ...
The Aileron on the Integral is big, and the build-in hinge have non-friction; leaving everything to the servo. Maybe i can`t expect anymore from the servo !? Probably; other servos would share the same destiny ...
This is why i hope the dampening fixture will be friends with them, extending the lifetime. The total weight of the dampening fixture is app 20-25 gram ( including bolts, washers, attachment, control-horn etc). This is acceptable together with the 9411SA which will put the hole assy ( damper + servo ) in the "normal" weight range compared to a high performance metal-gear servo. At the same time ; get the benefit of a very presise servo , which the 9411SA is ...
Kjell Olav
