RCU Forums - View Single Post - What is a Good Glue for Putting Together Blocks of Foam
Old 03-29-2003 | 03:05 PM
tweet_ip
Default What is a Good Glue for Putting Together Blocks of Foam
What is a good glue for putting blocks of foam together, that will then be cut with a foam cutter? I suspect that the Poly. glues will be too hard to drag a wire through. I tried a new Elmer's spray on glue that does not hold very well. I was able to pull the blocks a part by hand.
