RE: Are EI Units Interchangeable?
You may have to change the sensor too when you try the new IE, they changed the order of the wires into the plug. You can use the old sensor by rearranging the wires, but it's easier to swap out the sensor IMHO.
A weak battery can give you those symptoms too.
