Amp draw
I remember reading somewhere that someone said that if you keep the electric set up the same (i.e. same volts etc) but increase the resistance (prop) then you also increase the amp draw. That makes sense because the battery is being strained more, but if you look at the simple physics V=IR then if R goes up and V stays the same , then I (amp) must go down... Could someone explain me to what actually happens and which one is correct
thanks
