RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 11-01-2007 | 11:44 AM
  #1825
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: captinjohn
You can get a velocity stack from Horizon real cheap.
I'm to cheap to do that While my son was answering the door and children were screaming on the street I run my late and in not long time I made my own piece. I used derlin (lighter and cheaper than aluminium) as I did not have such big aluminium rod laying around. On the picture below you can see it already mounted on the plane. On the second picture you can see a a vent cover that is facing the firewall. I will modify this if velocity stack doesn't help.
ID:	794757   Click image for larger version
