Do you think that throw angle will be a problem?
The other problem I'm having is that the hardware package supplied control horns are 1/2" offset and the factory drilled all the hardpoints at 3/4" off the hinge line.
That angle will work just fine.
And the slight offset of the control horns will make absolutely no difference in the way it flies. The only place it matters even a little is on the pull-pull rudder where you like to have the pivots on the hinge line to keep the cables both tight.
TF
