RCU Forums - View Single Post - Pro level car setup? Anyone do this?
Old 11-01-2007 | 05:39 PM
Foxy's Avatar
Foxy
Default RE: Pro level car setup? Anyone do this?
Ah, I see. Sorry, the way your post was phrased sounded like you wanted set up help... I still say you should do the work yourself though, that way you'll learn how the buggy works and be able to repair it yourself, etc etc. Almost like building a kit again. You can also change the oils in the shocks, diffs, etc when you rebuild them, so you can apply a base setup that you are sure about, it'll be a worthwhile experience. Hyper parts are everywhere, it won't be hard to find what you need in order to repair them, and cheaply, check out ebay.
