RE: thunder tiger GP .07 problem
Make sure plug is ok --step 2 disconnect the fuel line prime hit with the starter it should run for a short burst- if it does then put line back on start at 1 1/2 turns open if starts and dies open a half turn at a time till it stays running make sure you are wide open on throttle martin
