RCU Forums - View Single Post - common arf mistakes?
Old 11-01-2007 | 10:01 PM
Charlie P.'s Avatar
Charlie P.
Default RE: common arf mistakes?
ORIGINAL: panzertank
i was looking at getting an glow powered arf sometime in the future. I have 0 time building planes and was wondering what are the mistakes i will make. I know some info about building but have never built anything myself. anything that has troubled you in your building will help me build my plane. thankx.
First mistake is thinking you build an ARF. Some guy in China built it. You'll be assembling the modules.
I always use thinned epoxy (polyurethane wood finish will do) to fireproof the tank compartment. Not the whole inside - too much weight. I also epoxy strips of 2 oz fiberglass cloth inside the firewall down either side. Had the firewall pull off a G.P. Big Stik ARF (luckliy found before take-off) and have not trusted one since.
Lay out the hardware ahead of time. You don't want to use the wrong part, cut the longest rod if a shorter one is in the box, etc. I just assembled one that had extra wheel collars but was midding the landing gear bolts. Oops.
Do not cut the receiver antenna no matter how long it seems. It's a tuned wire and has to be that long.
Use 30 minute epoxy wherever epoxy is called for - just my preference.
Check the center of gravity twice and have someone else check it for you before you fly. There was just a post where a fellow got it wrong and augered in on his maiden and thought the supplier should send him a new plane. Nuh - uh.
The aileron goes up on the side you point it towards when you're standing behind the model. This is important. Right aileron = right aileron goes up.
Servo screws should be tight. But they're tiny and it doesn't take much strength. Don't ream the wood by over-tightening.
Ask lots of questions here if you get stuck. This is an astounding resource.
Have an experienced pilot do the trim (maiden) flight for you. They can be tricky. He/she will also do a good preflight and hopefully spot any glaring errors that would cost you the model in a crash.
