RE: 450 SE Tail Servo Binding Question
So Limits on the Gyro will effect how much travel the servo arm has? Basically when I go full left rudder I get full deflection and everything is OK. When I go full right rudder the tail servo makes that grinding sound because it's tryin to pull the further than the tail slider will mechanically allow. I'm nearly positive it's because I'm using a different servo arm now since nothing else has really changed.
I've got the servo on the boom right, everything is centered I'm just trying to remove that binding and grinding sound.
