ORIGINAL: gamesbeer1
sorry to jump in, but can i use jb weld to fix a leaking fuel tank? thanks
Epoxy does not break down when fuel is splashed on it, or when hot exhaust residue hits it. And the oily mess won't usually affect it over a few months.
But put epoxy under fuel or where it's exposed to it for long periods of time and it will break down. And J&B is basically a metal filled epoxy.
If you don't expect to use the fuel tank for very long, the J&B should work for awhile.
I made some fuel line plugs by dipping the ends of 2-56 bolts in J&B. The J&B was basically to give a bulge. They worked for about 6-8 months and I started getting crap in the fuel. And one day, noticed when I pulled the plug the end stayed in the fuel line. And when I picked it out with a pin, it came out is bits and pieces.
