Hey, Bry.
Did You read my tips?
http://www.rcuniverse.com/forum/m_6554024/tm.htm
I bet the flybar is binding or You have the blades too tight. The blades definately need to be a little loose and it will self align; it will be uncontrollable with them tight because You can't get the alignment perfect enough. You can get real close, but only itself can get it perfect; so loosen up !
Gary
