RCU Forums - View Single Post - Peakmodel, which one???
Old 11-03-2007 | 02:39 AM
altidsulten
Default Peakmodel, which one???
Hi,
I am going to get one of peakmodel 25% models. I have a Moki 180 gasser that I will use, it is a guite heavy engine (around 2 Kg, with silencer and prop( a little over 4lb)). My favorites are their Edge 540T, Su-26M, Extra 330L and the Yak-54. I am afraid that I might need lead in the tail. If any of them has a tendency to be nose heavy I guess that will not be the one to select.
1) I would like to know which one has the shortest nose or if it would be easy to shorten it (does not looke like it is taht easy from the pics on their website) The Moki is 6,25"/15,3cm from the propbackplate to the mount.
2) Also what is the cowl diameter/width on these models, can they contain my engine? (5,5"/14cm from centerline to the top of the sparkplug)
The Edge seems a little lighter and has a greater wingarea, but does it really matter for a novice in 3D???
Regards
Thomas Pedersen
Denmark
