RCU Forums - View Single Post - Waterproof/Sealer for float plane kit?
Old 11-03-2007 | 08:34 AM
JimCasey's Avatar
JimCasey
Default RE: Waterproof/Sealer for float plane kit?
I'd be reluctant to use ANYTHING before it's glued....sealer seals glue, too.
However, major subassemblies that are likely to get dunked (basically anything in front of the spar) should be sealed. I use water-based polyurethane varnish as a brush-on, or the stinky spray-can poly if I am spraying it. Polyurethane is very chemical-resistant, and covering sticks well to it. I also use WBPUV as the adhesive when I glass the floats or hull of a plane. Not toxic like epoxy, and plenty strong. It will Wash-off if I screw up, instead of soaking stuff in solvents.
