RCU Forums - View Single Post - Crashed
Thread: Crashed
Old 11-03-2007 | 02:10 PM
Defmeq
Default RE: Crashed
I jumped it about 4 or 5 feet in the air and it landed right on the left tire, bent it all the way back around so the outside of the rim was facing the exhaust. And by the way, DO NOT pull out your front drive shaft and try to run an avalanche rear wheel drive. I knew it wouldnt be good to just pull out the front 2 dog bones and let the front diff run without any load on it so i took off the whole front end and pulled out the front drvie shaft. All was well untill I gave it some gas and the clutch slipped horribly. I'm 99% sure that if i had kept running it would have burnt up the clutch. I'm a little confused as to why it didnt work but it just didn't. I'll never attempt this again. And i did bend the dog bone back but I'll still buy new ones for it.
Defm~
