RE: Help with Triton2 charger
On your Triton: the battery must be inbetween the voltage for 2S and 3S because it says too high for 2S and too low for 3S.
Charge on a nickel setting for a few minutes at a low rate and the voltage will come up enough to charge it normally on the 3S setting with the balancer.
Please don;t forget about it (set max capacity or stare at the volge while chargeing) Also you can push both square buttons to read the input voltage and the output voltage of the Triton , this will give you the battery voltage (output)
