RCU Forums - View Single Post - First flight of DP extra today
Old 03-30-2003 | 06:10 AM
Kallikrates
Default First flight of DP extra today
No it didn't flutter to peices
flew with the battery pack in the nose the fuel tank right infront of the wing tube
futaba 9303's on elevators
hitec 5625 on ailerons
borrowed jr 8311 on rudder
all on 4.8 volts
Moki 1.80 on power (18/10 prop for breakin)
I know the prop is all wrong but its all I had. I haven't weighed it as no one I know has a scale but the power was there, not enough for hovering (it holds but doesnt seem like it wouldpull out This was tested fairly hiugh up also) but we'll see as I get a better prop drop the cg back and the engine gets a few more tanks through
solid flying ship that I couldn't get to stall but very stable tomorrow I'll experiment with moving the cg back and mabye try an old pro zinger 18/8 if the weather holds out
questions comments are welcome
PS the plane was built almost totaly stock cept I added hinges imbetween the stock locations used radio city 1/4 hinges and rocketcity hardware with central hobbies cotrol horns oh and I also flew with a little random stick of lead on the nose just to besure I was 100% on the docile side of the cg range
