RE: help choosing which nitro engine
I am assuming that you are going to use this in a pusher configuration like REAL swamp buggies so you will need a pusher prop. I'd also pick a remote needle valve to keep your hand away from the prop. Prop size?? I'm guessing (and it's just a guess) 3 blade 12x6 or in that range.
Most likely none of this is in the manual.
