RE: SECRETS OF THE MINI ULTRA STICK
Doc, do your MUS's exhibit any roll when using the rudder?
Mine rolls quite a bit when I use rudder, especially in 2" high rates. I usually don't use the rudder much at all but sometimes when I want to do some flat turns I use rudder and manually feed in opposite aileron to keep an almost flat attitude which results in a nice smooth flat turn. Do you use any Rudder-to-Aileron mixing?
