RE: Reassembly of engine, but 1 problem.
If you put the engine AND the thrust washer in the freezer you'll be in the same boat, just with cold fingers, because the thrust washer will shrink too, you just want the shaft to shrink, and the hole in the thrust washer to stay big.
