RCU Forums - View Single Post - loose muffler US41
Old 04-01-2003 | 08:09 PM
Bax
Default loose muffler US41
TR,
Sometimes the muffler bolts are a hair long, and are bottoming out in the holes before they are really tight. You might want to check that. If so, just shorten them a bit at a time until they no longer bottom out when you tighten them.
Another way to help keep them tight is to insert a piece of monofilament line into the bolt hole and then insert the bolt. It acts just like the nylon insert in a nut.
