RCU Forums - View Single Post - Don Smith P-51D
Old 11-05-2007 | 12:56 AM
  #47
richard2287
Default RE: Don Smith P-51D
I wonder, would one of you guys take a look at your wing plan, and tell me just how the ail. LE. is suppose to be installed. The plan says to build and cover wing complete. Then cut out ail. and flaps. So if you do it that way, you would have to have the LE. cut into pieces to go between the ribs. If you install it while building, but are suppose to make it a one piece install, you have to cut out some of the ribs, and this is not indicated on the plan, or on the ribs. And at just what angle are you suppose to install the ail. LE? Do you notch it for the one eighth by one quarter front top spar, or does it go under that, and lean back toward the ail. spar?
Something has either been left out here, or I am missing something.
Thanks for your time.
Rich.
