RCU Forums - View Single Post - Advantages of an airfoiled stab?
Old 11-05-2007 | 09:40 AM
dieFluggeister
Default RE: Advantages of an airfoiled stab?
Efficiency is the main aerodynamic difference between a flat and a symetrical foil. It will not make a difference in the CG. If your wing airfoil is symetrical then I would say that you can keep the same incidence and it should be fine.
