Likely (but not always) the CG on a trainer will be on the spar . make sure your fuel tank is completely empty when balancing. and no breazes from furnace etc. balance laterally as well by holding it with a loop of string to the prop shaft and by the tail end of the fuse(a well centered pin helps). this will make a much better flying plane
good Luck
